1 - 12 of 12 Posts
Hello everyone,
I purchased an MM TA on the DotD back in December and I'm getting the rest of the car ready for the install.
I currently have Ford Racing short tube headers, a Bassani off road x-pipe, Bassani mufflers, and Flowmaster tail pipes. I'm looking to make the move to long tubes and figured I do it now since the x-pipe needs to be modified to work with the TA and I'd like to do it once.
Question I have is, what is everyone else's setup that has the TA and long tubes? I've heard nightmare stories about BBK and I'd like to get a less expensive set of headers and keep the Bassani X but it looks like you can't buy a Bassani X pipe that isn't for Bassani long tubes.
just to make this clear you wanna run longtubes and keep and mod your existing bassani x-pipe that's for shorty headers ...???
No,
I was saying I'd like to stick with Bassani for the X (I've had two of theirs and their fit/finish/quality is awesome), but they don't seem to make one that works with long tube headers except their own.
Question was, what is everyone else using and how happy are you with your setup?
that's true and i think you should consider getting one of those piece together make your own x pipe kits and have some shop or yourself if you can potentially cut and reweld some sections do the install
That's the rub, I don't weld, nor do I have any equipment to weld. I've already got to start a search for someone to weld in the SFCs and the TA mount, I'm figuring that'll be the place that does any exhaust mods but I'm really trying to get a plan of attack together so that I go into this with as much info as possible.
Is there no one here who runs LTs and an X-pipe with an MM TA in a Fox?
I'll be finding out later in the spring. I too am very concerned. The good news is that my dad (bless that mans soul) got me a nice welder for X-mas so Its maden voyage will be the TQ arm install. I'm going with their HD one.
I'm running BBK 1 3/4rs with a DR gas X (which was assembled from 5 pieces then welded) I also have Vert engine mounts which places my headers rediculously low.
Totally keeping my fingers crossed I don't have to do to much as being a newb to welding.
Good luck with your install.
The TA is the first thing on this car that I haven't done myself (other than the roll bar which was in it when I bought it). I just cringe at the thought of letting someone else do this big a job on my car but I know I'm out of my league on welding so I'm working on finding a decent shop. There's one MM dealer in the state of IL and luckily they're local and a shop, so here's to hoping they've done an install on a TA before and aren't incompetent.
Although I have shorty headers, an exhaust shop made an X for my car. It cost a few $$$, but I only had to pay once. They relocated the cats, made and moved the X so now there is no interference anywhere. No rattles, banging, clanging or clearance issues.
Sorry, forgot to mention, yes it is the HD TA. Thanks for the tip on VRS, I'll check them out.
well they say the HD tq arm doesnt clear that stock location of the midpipe to CB ball-joint connections.
Bullitt1992, Chris, just did this install, and his is also HD. He hasnt had the exhaust "fixed" yet, and its not bad at all. I have yet to hear him bitch about rubbing the exhaust on stuff. His car is pretty low for sure.
Dont get me wrong, the exhaust would def tuck better if the flange was moved, but its not exactly the end of the world if you dont move it.
Of course, this is on a New Edge, so your mileage may vary.
98 GT with SLP x pipe and long tubes seem to fit fine with the HD TA im putting in right now. Looks like I have about 1/4 inch clearance without moding the x pipe. The flanges on the slp x pipe are much smaller than the stock ones and the ones on my magnaflow catback. The flanges on the magnaflow catback are going to rub if I don't mod them or switch them out for the smaller ones. Summit sell the smaller ones.
1 - 12 of 12 Posts
