Banned
MT FRIEND IS ATTEMPTING TO DO THIS.THE CAM IS IN THE ROCKERS ARE ADJUSTED AND IT TURNS OVER PERFECT.IS THERE ENOUGH CLEARANCE.HE DOESN'T WANT TO PULL OFF THE HEADS.JUST WONDERING IF SOMEONE HAS DONE THIS.WOULD GREATLY APPRECIATE ANY OF YOU GUY'S INPUT.
I currently running an x-cam, TFS, but SRP pistons, 1.6 RR. Trying to see if I can run a larger one....
I just installed my custom cam, 228/236, .540/.545 on a stock short block with tw heads. The car turned over fine, crank it up and ran like a champ. Until I went WOT to redline, now I'm replacing 8 intake valves. What ever you do, don't preload the lifters cause they will pump up at high rpms and then you will be replacing valves. Oh well live and learn.
The correct answer is no-one knows. You will have to try the clay method to make sure.
