I HAVE A BULLET PROOF 408 STROKED WINDSOR THAT I HAVE OVER $16000 INVESTED IN. PROFESSIONALLY BUILT WITH ALL BILLET INTERNALS. ONLY HAS A COUPLE OF DYNO PULLS. MADE OVER 600HP WITH A MILD TUNE WITH A SOLID ROLLER CUSTOM NITROUS GRIND CAM. MOTOR IS TURN KEY AND HAVE DYNO SHEETS. MOTOR IS LOCATED IN TIFTON GA.
Discussion Starter #2 (Edited)
motor
I HAVE A BRAND NEW NEVER RAN IN CAR ONLY A COUPLE OF DYNO RUNS ON MOTOR. THE CAR PUT OUT OVER 600HP ON MOTOR WITH A NITROUS GRIND SOLID ROLLER CAM. MOTOR IS 13.5.1 WITH FLAT TOP DIAMOND PISTONS. THE BEST OF EVERYTHING IS IN THIS MOTOR NO EXPENSES WERE SPARED.
1050 QUICK FUEL
DART SPORTSMAN 4 BOLT BLOCK
SCAT BILLET H-BEAM RODS AND CRANK
RACE BEARINGS
DIAMOND FORGED RACE PISTONS
TOTAL SEAL RINGS
MOROSO 7 QUART FOX BODY OIL PAN
RACING OIL PUMP
ARP MAIN STUDS
COMP CUSTOM 750 LIFT SOLID NITROUS ROLLER
COMP SOLID ROLLER LIFTERS
COMP HARDENED RACE PUSH RODS
VICTOR JR PORTED AND POLISHED HEADS
2.05 INTAKE 1.60 EXHAUST VALVES
1.65 ROLLER ROCKERS
ROLLER ROCKER GIRDLE
SHEETMETAL VALVE COVERS
VICTOR INTAKE
MSD BILLET DISTRIBUTOR
RACE WIRES
EVERYTHING BALANCED AND MACHINED TO SPECS
BUILT BY PROFESSIONALS AT GRIMCO PERFORMANCE IN BRUNSWICK GA. EVERYTHING IS NEW IN THIS MOTOR. I HAVE OVER $16000 IN THIS MOTOR BEST OF EVERYTHING. THIS MOTOR WILL GO INTO THE 5'S IN 2400LB CAR OR TRUCK.
