1 - 15 of 15 Posts
1987 gt, ac pump wont turn on. i have power to all components on the the passenger side of car. when i bridge the wot relay the pump turns on. any idea what could be my problem?
Check for power to the coil
The ecm controls that relay
If I am not mistaken, the clutch on most AC compressors will not engage if it is low on refrigerant either. The refrigerant is the lubricant, so they don't want the compressor running without it. There is a pressure switch in the circuit as well. I am by know means an expert, just saying in my experience refilling, the compressor never comes on until a few cans are installed.
I put 2 1/2 cans in the system. when i bridge the relay it runs cold. Indy,which coil are you referring to?
the coil of the relay you jumped
how much refrig you put in the system means nothing
you use a voltmeter to test a switch.
the refrigerant is NOT the lubricant
the pressure switch is there to prevent the evap from freezing.
the relay has power on 2 of the 4 wires, power from the pressure switch, power in from a red cable. the orange cable from the ecm has nothing and the black and green cable that goes to the ac pump has nothing. going to check the ecm pin and make sure its connected then recheck the pressure in the system. i replaced the pressure switch with a r12 switch, but going to look into a r134 switch. rock auto has a different part number. i noticed that the relay also has 2 part numbers, one is $9 and the other is $28. do you know if thats a special relay or just a regular relay?
why are you changing parts?
can be adjusted with gauges hooked up, and turning the adjustment screw, under the plug
did a maf coversion on this car a while back and wondering if the ecc orange wire on the wot relay is in the same position(pin 54) for a years. found 88 thru 93, cant find 87
Test the pin with test light to batt pos
Turn on a/c and snap to wot
Discussion Starter #13
pin iam asking about is the orange wire which grounds the relay. just need to now what position it is on a 87 car. thanks
like I said, use a test light to confirm,
battery positive now, when the ecm grounds it, the light will come on
Orange/Light Blue
Probably can't see the blue, anymore.
The ECU grounds this.
It should be the same for '87, pin 54. ECU for both was the same Speed Density. Calif was MAF for '88.
You can test the relay without turning the engine on.
Turn ignition ON, Turn the AC on & off. You can now hear the compressor clutch engage & disengage.
Remove the connector & substitute a test light.
Sounds like the relay coil is bad.
Disconnect the relay from the connector, put ohmmeter across where Red & Orange Lt Blue were, should read 100-200 ohms, not infinity.
The relay is "special" because it mates to the Ford connector & has an attached mounting bracket.
If the cheaper one plug in to the factory connector, you probably can use that.
Give us pics.
I just got my Megasquirt ECU wired to perform this function.
The connector insulation to this relay was in bad shape on one wire, was able to tape it up. First time it was removed in 30 years.
UPDATE:
Found the 2 relays on Rock Auto. $16.07 & $20.89
1 - 15 of 15 Posts
