i have a chance to buy some after market 17x9 cobra rims. they have 24mm offset, and 255/45 ZR-17 tires. Will they fit?
You will more than likely have clearance issues with that tire and rim size up front, especially if your car is lowered.
They will fit fine. I have 255/40/17s on my 90 GT. The only thing that rubs is the wheel on back of the A arm. I am going to grind the jacking pad off the back to solve that issue shortly.
If your car is not lowered, you might get away with it. What I would do is put one of the wheels on the front and see how much room you have( put weight on front of car and turn steering wheel from lock to lock) before handing over the cash. A set of rack limiters will probably fix this.
