Will a lightning blower fit on top of a 99+ mustang engine??
Thanks in advance..
P.S. what would it take to adapt one to a mustang, if not.
US Air Force Active Duty
It won't fit, because the Lightning's 5.4 has a taller deck height (meaning the cylinder heads are farther apart).
You might be able to find a different lower intake that would adapt the blower to the 4.6.
I don't think you'd want the 5.4 blower anyway because the intake is still on the top of the blower, vs. the rear entry of the Mustang. You'd still need a pretty big hood to clear the blower.
See this link for an idea, a 4.6 with the same intake will probably only be about an inch shorter, if that:
http://www.mustangworld.com/ourpics/News/select1716.htm
Well there are at least 2, maybe three companies that make Eaton kits for stangs. So why not use one of those instead of trying to create your own.
KP
