Hey guys, I've got an 2005 Saleen with a 60mm front mount Hellion single turbo kit and I need to find a cooling solution. I run the car hard at open track days and it gets warm, would overheat if I'd let it go..
It doesn't seem there would be enough room to fit a bigger rad and it would suck to order a rad and find out it doesn't fit.
An alternative would be an oil cooler to help control the temps but means having to use an oil filter relocator kit, then installing a cooler in line between the relocated filter and the engine >>> allot of oil lines and fittings all over and not sure it will cool enough
if anyone has solid experience with this it would be really cool if you could share...thanks
I would call them and ask , they would know and have great customer service.
Actually ya I emailed them. Waiting for response.
I've been searching the web and it doesn't seem like there's allot of guys lapping with this kind of setup. Maybe I'm not looking in the right places???
