1 - 12 of 12 Posts
I need some sidewall to sidewall (overall width) measurements for a M/T 28x10.5 ET Drag or a Goodyear 28x10 slick on a 15x9 rim.
I can get it for you when I get home tonight.
Thanks John. You're the only guy on here that I know is running them.
I'm trying to see if I can fit that tire/rim combo under my Futura without narrowing the housing.
That turns out to be a dang tough measurement to make but it's around 12 3/8" across the buldge (+/- 1/8").
US Air Force Active Duty
Does anyone know the sidewall to sidewall (overall width) measurements for a M/T 28x10.5 ET Drag slick on a 15x10 rim?
Fomoco347 said:
John91Coupe, is that a 5.5 backspacing?
Yes, mine is a 5.5" backspace.
I also run the 15x9 with 28x10.5 but on a 6" BS wheel. The fit is great with only minor BFH clearance on the inner wheel well.
Discussion Starter #12
Thanks everybody,
I wasn't able to get to the computer over the weekend. Thanks for the measurements. Glad to see it's close even on the 10"wheel too. Hopefully I can fit an off the shelf rim under there and not have to narrow the housing.
John
1 - 12 of 12 Posts
