1 - 19 of 19 Posts
I am basically going back and forth between my stage 2 trick flow and my stock cam, I like the driveability and smoothness of the stock cam but dont want to sacrifice a bunch of power.
Who is running their stock cam and what does the RPM peak at, my biggest fear is bringing the RPM peak down to like 5k
Stock cam here!
Holley System Max Intake and Edelbrock Heads.
Makes power from 5k to 6k
http://75.180.27.125:50001/Dyno Graphs and Pictures./Dyno Graphs/Brian 88 Twin Turbo Mustang.jpg
Me too, mine drops off around 5300 on the dyno graph.
In that case maybe ill keep this trickflow
I would run a custom grind cam, or the ford e cam.
my 1990 gt has the stock cam and it ,makes 535/622 with dart sr,gt-40 intake, however car shifted at 5200, i think i would go with the TFScam:king:
How much boost?
stock cam would be a better choice then a TFS stage 2 cam for a TURBOCHARGED Setup!
Sorry for the hijack but Bob what do you think the max power would be w/ the stock cam. Just estimating or experience. 1000 rwhp?
Im running a stock cam retarded 4* and 1.7 rockers .
should have stock times within the week.
Stock cam straight up.
Discussion Starter #17
Well I decided to just throw in a stage 1 trick flow..
Still stock cam here, car made 484 hp, 559 ft/lbs to the tires on only 16 degrees of timing and 12 lbs of boost.
Stopped there to try and preserve the life a little bit.
How long till you run it on the dyno w/ the trickflow? I'm curious to see how it affects it compared to a stocker.
Will
Discussion Starter #19
Gonna be a while, yesterday was the two week mark on my turbo kit order, was supposed to be a two week lead time so we will see.
1 - 19 of 19 Posts
