So finally my diy turbo kit is going underway tomorrow. The car is a 87 gt converted to maf stock heads, stock shortblock with f cam, systemax intake manifold with a mpt70. So what sparkplugs do you guys recommend? And also what oil?
stay with the same oil you have been running and for plugs with stock heads i would use autolite 24's
I agree. One thing about turbos is the closer the split in the weight of the oil the better less cook off. I run 10w40 caster oil and have run Rotella 15w/40. Just remember that the zink Phosphates additives in oil is less than it use to. This means less protection. May want to run an additive like Prolong or Zmax. As far as spark plugs I run NGK only.
rotella and ngks all day long!!
