I am doing a LSX swap that should be in the 425-450 HP range.. I am leaving all the stock lines, tank, etc on my 92 coupe.. plan on plumbing them into my feed/return on the intake... what size pump would anyone suggest?
240 or 320, I used the corvette filter regulator that has the return built in and set at 58 psi. works good, I've had this way for over 12 years.
Im running truck intake that has feed and return fuel lines.. Just wanted to verify which size pump I'd need while I have the tank dropped
A 255 will work fine.
Tim
