I'm looking to upgrade my roll bar and was wondering if you guys can post some pics of different roll bars in a hatch car! And post experiences and such and what one is recomended?
rollbar
we put 2X3 connectors thru the floor with pieces going from the connector to the rocker and welded to the area that kicks up for the rear seat area and weld the hoop to these, then we drill a 1/4" hole thru the upper tork boxes, from the inside drill a 2 1/2" hole(with a holesaw) thru the layer of floorpan only, this exposes the tork box. weld the torkbox to the floorpan, weld the 1/4" hole then put a piece of 1 1/4 X.065 tubing from the hoop just below the crossbar to the tork box. This gives you additional triangulation and keeps the torkbox from ripping out of the car.
Jon
http://www.tubechassisdesignz.com
I like wolfecraft racings cages. There alittle more than others but are well made and fit like a glove.
-tyler
RobKong
S&W
Check out the tech section at www.mustangcentral.net for a detailed article with pics on a cage install.
