1 - 16 of 16 Posts
I am looking to add relay to switch a power output from one device to another.
I currently have my 2 step on a momentary switch in my center console and my Nitrous arming switch on a toggle next to it. (Nitrous is signaled from WOT signal once armed).
I would like to rewire the system so that when armed the power is sent to Nitrous system and when the 2 step momentary switch is activated it interrupts the nitrous signal and powers the 2 step.
Does this make sense?
relays have normally open and normally closed contacts
how to you want power to flow?
I want power to flow to the NOS Sol and be interrupted by a momentary switch to send power to the 2 step.
so you have two signals
you will need two relays and run the power from the nos through NO contacts of the relay it will control, that power will then go through the NC of the other relay controlled by the momentary switch.
the relay controlled by the momentary, will have 2 step power through the NO contacts of its relay
when you hit the momentary that will open the NOS circuit and complete 2 step circuit
you follow?
need a diagram?
you follow?
need a diagram?
Yes, a diagram would be very helpful.
I was wondering if an relay existed that would switch the power output from one to another?
you have 2 independent signals, yes?
you want to use a $$$$ logic controller?
or inexpensive readily avai relays?
I only have 1 signal, the signal for the 2 step.
I want constant power to the nos and I want the 2 step momentary to disrupt the power to the NOS and power the 2 step.
Does such a thing exist?
And no I don't want to go the $$$ if I don't have to.
I am thinking like how a high beam relay works in a 4 eye car, turn on headlights and when you click the high beams on it turns off the low beams.
Okay, you want the NOS armed all the time
easy
i will try to squeeze time in between miller high lifes
Thank you sir.
does this momentary switch latch, stay on?
do you want to switch power or grounds?
Discussion Starter #13
Momentary is help down only while on step. Then released when launching and that is when I want the nitrous to turn on.
I would like to switch power.
so you are going to hold down the momentary ?
as soon as you release, you want it off?
this important, so i dont latch it
also PM your email, to send the diagram
Here ya go. Simple dual relay setup with 1 relay acting as the interrupt. I wrote "trans brake button" instead of "2 step" but it will work the same as long as your 2 step button is a 12v source. Diagram attached...
Also, this can be configured in several different ways. This will help you get a picture on what the logic looks like and you can set it up for what works best for you...
Discussion Starter #16
Thank you sir, I'll try and get it wired up this weekend.
1 - 16 of 16 Posts
