1 - 9 of 9 Posts
1985 Fox HPDE build. My brake setup will be stoptech 13" front and 11.65" Cobra rear. I have the cobra booster installed. If anyone is running a similar setup I would like to know what MC you are running. I was thinking the 1" bore.
I'm waiting on Wilwood Superlite 14'' front kit to arrive myself & I'm curious about pedal feel once I get mine installed. The '93 Cobra (1'' bore) was on back order at the time I went disc in the rear so I have the 94-95 Cobra (15/16'' bore). Maximum Motorsports suggested to go with the '93 Cobra MC to stiffen up my pedal feel, but the difference between the 2 options really comes down to driver preference... we'll see.
I'll try to report back asap on my end.
A friend of mine runs the 15/16 bore with the brembo setup but he's a cmc race car. I ordered the 93 cobra 1" on MM's advice. Please report back, I will be very interested in your findings.
I'm running the same setup as you Stoptech 13" front and 11.65" Cobra rear and was unhappy with the squish of a 15/16 bore.
Spoke to the tech team at Maximum about it and changed to the 1 1/16 bore.
BMC-3 Master Cylinder, 1994 GT, 1-1/16" bore, new, 1979-95 Mustang
Using the stock 92 brake booster with it and I've been much happier with pedal feel and travel on track.
86 Mustang GT, typical Cobra 38mm twin and 13" in front, but 45mm single SSBC/93 Cobra and 10.25" in the rear. Stock 86 booster. First tried the SVO 1-1/8" bore M/C but with little luck (could not get the rears to lock). Pedal feel was fine. Then tried the 93 Cobra 1" M/C with the same results. Not much change in pedal feel and no rear lock. Then I discovered my SSBC manual prop valve was notworking - basically cutting fluid flow to the rears no matter where I set the knob. Learned this after the car was put into resto-mod. In any event, I've moved to StopTech 4-piston 14s up front with typical 11.65 Cobra rears. Keeping the 1" 93 Cobra M/C but upgrading to the 93 Cobra booster. Should be a perfect match given StopTech's design for these cars. No more manual prop valve problems either - also went ABS conversion.
Cool. I'm running everything the same except 13". The 1" bore MC should be fine. Thanks.
I see you went with the 1'' bore MC, however I'm reporting back since I've been running the 6 piston Wilwood kit (with 15/16'' bore MC) for about a month now. NO "squish" in my pedal feel at all. I honestly cannot feel a difference in pedal feel since the upgrade. I think the main reason is that I upgraded to all stainless steel lines front and back at time of the front brake swap. I'm sure that balanced out the pedal feel & I'm pretty certain I would've gotten some "squish" if I hadn't went to the stainless lines.
I actually returned the 1" and went with the 15/16". I also Swapped all 5 rubber lines with stainless and the pedal feels fine, actually I am very happy with the entire brake upgrade. But I guess I better be for what I $pent on it!
I haven't installed my Stoptech's yet, I still have 2 more sets of PBR pads to use up first.
I changed my master cylinder from a 1 1/6" to a 15/16" and am much happier with it. I am running an SN95 booster.
Jamie
1 - 9 of 9 Posts
