Which one of these electronics will work for a blow threw,or will neither?The one on the left is from my PRO-M and is calibrated for the 60's i have.The one on the right is calibrated for my 42's i had and is from my LMAF.
Discussion Starter #2
This is the flange i bought from a member on here to weld onto my IC pipe,but neither electronic will fit!
if you expect it to run well with no tune then neither !!
The LMAF looks more like my PMAS pro tube then the pro-m does if that helps at all.
I'm sending my chip to my tuner and have him burn it,for a "start up" tune then when it's up and running i'll trailer it to him and tune it on the dyno.I figured out i need to trim a hair off the flange to get it to work,and also retap one of the holes so the bolts for the MAF will match the flange.
