1 - 16 of 16 Posts
I've tried searching, but the more I search the more different part #'s I find. Just trying to see what the majority of you guys are using.
I'm running the on3 kit w/ MP t70. I'm running a blow-thru setup w/ a 750cfm CSU carb, victor jr. Intake, stock e7 heads. Will prolly start out w/ 9-10lbs of boost and 18* timing. I've got my ARP head stud kit.
I would like the head gasket to be somewhat of the weak point. Any input would be greatly appreciated
Felpro 9333pt1
X3
Thanks a bunch guys. Saw so many different ones people were using, wasn't sure which one to go with. Doing the ARP studs and head gasket this coming weekend and hopefully starting on the turbo kit the following weekend. Still waiting on the carb from CSU
May i ask whats the most boost you would consider running with those gaskets, head studs and stock bottom end?
May i ask whats the most boost you would consider running with those gaskets, head studs and stock bottom end?[/QUOTE
As long as the tune is good that gasket will out last the amount of boost a stock bottom end handle.
I'm not sure what the final PSI will be, but I'm shooting for 450hp, so I'm thinking about 10-12psi. I'm not going over 450 on this block
im shooting for the same as i am running a stock block for now. Thanks for the info
Put the boost to it. Its just air!
I searched before my build and I got a few different part numbers, BUT I looked those numbers up to see what the differences were...that helps understand when and why to use a certain part over another. Just a lil fyi...good luck and have patience.
You talking about different head gasket numbers? Can u elaborate?
different firing rings, thicknesses, gasket materials stuff like that.
1 - 16 of 16 Posts
