My drivers seat is out and I need to know which fuse it is. All the inside fuses look good. Help!
My 30 amp went out under the hood. I will have to check the others. Hope that is it. Thanks.
If the seat isnt workin, for sure its the 15amp fuse... second one from the fender... not sure of the #. but its a 15A... believe me ive replaced mine plently of times, only cuase i run my neon and fan switch off the same circuit... seat, cig lighters, run off the same cicuit. so try and test out that cig lighter in the ash tray, bet it willnt work. or maybe im thinking of the accessorie outlet by the shifter...
