1 - 20 of 20 Posts
TURN OFF THE CAPS LOCK.
If your a stick car lift bars will shock the tires hard resulting in spinning, the weight jackers are good for setting the IC on the car and letting the front end help hook the back end.
Sorry about caps lock!
It is a stick car weighs 3270 with me in it best 60ft was 2.1 has lift bars now just think something would work better.
Thanks Dave
You will have to leave about 2000 and feather the clutch to get it too hook up and then mash it and don't let up while you shift.
Its not spinning so much as bogging I am going to try a 410 rear that I have it has 373 now and was going to change arms at the same time. Plus I think it needs more timing its at 11 degrees now. I have lots of changes to make the car is new to me.
If its bogging then leave harder or put more air in the tires.
What is your ET and MPH? Timing varies on every car, I run 18* initial timing on my car and 38-40* overall, however I run a mechanical advance distributor where I am carbureted.
Discussion Starter #12
The best et was 13.89 at 110 mph it is a 347 victor jr heads victor 5.0 intake it is injected still have a t5 to so it wont take much abuse
Something is defintely wrong with your combo, that should be a mid 11s car easy. Post your entire combo up engine, compression, cam, injectors, wheels & tires.
Discussion Starter #14
DSS level 10 block
eagle stroker kit 10.5 cr
comp cam int lift .565 exh 585 050 dur int 232 exh 244 adv 283 294 114 sep
victor jr heads
victor 5.0 intake
75mm tb
anderson power pipe
90 mm mass air
ford racing 42 lb inj
13/4 shorties
21/2 flowmaster exh
wc t5
ford alum drive shaft
373 rear lift bars
eibach drag launch kit
lakewood struts
275/50/15 mt drag radials on ten holes
i think i just cant drive the manual
Cam is a little small, loose those lift bars and get some regular control arms, get some long tube headers in 1 3/4" size, and change to a 4.10 gear. And for goodness sake put some 24lb injectors in that car. Who told you to put 42's?
The 5 speed is hard on the radials as it shocks them too badly to get them to hook, you need some slicks and drive it like you stole it. If your afraid of breaking something then save your money and stay home.
Discussion Starter #20
I had an Anderson cam and this is the recomendation for it
347-408 c.i.d. Best performer for 347 cu. in., 1.6 R.R. & 6600 rpm and 10.7 to 11.5 comp. Great with TFS or Edelbrock Victor Jr heads. Minimum 38lb injectors and 80mm mass air. Recommend 4.10 to 4.30 gears, poor drivability under 2300 rpm, lumpy idle, rpm range 2800-6800, needs 3500-4000 converter. Must use AFM valve
springs.
Works great on 6900 rpm 10.5 to 11.5 comp. 302-331 c.i.d. with 4.56 gears and 30lb injectors. Must use AFM valve springs.
1 - 20 of 20 Posts
