1 - 9 of 9 Posts
I have a stock cam, the cam currently in the car is lunati voodoo 10350703LK, tfs1 or crane cams 449651. I would think the crane cam would be the best since it is like a f cam. but let me know what you think I should run. Heads are some cheap patriot performance heads. I won't be changing them any time soon. But what do y'all think I should put in the car?
That's what I have a stock speed density Cam..if you have a stock block that's what I would run...
I own all these cams already so I still should run stock cam?
Does it have a stock block?...what are your goals...I run one and I love it...
Yes stock block. I don't mind on how long it last. Having a 408 built for boost in jan.
No reason to get a custom cam. when I know at least 2 of cams I got will break the block.
stock block=stock cam
1 - 9 of 9 Posts
