1 - 9 of 9 Posts
Trying to figure out where you guys are mounting your trans coolers at. I have no extra room with the intercooler up front. In the driver fender with fan is all I can come up with. Biggest cooler I think I can fit is gonna be 11"X11"X1.5" and then mount fan on it. 29,000 btu is the rating. That gonna be good enough? Combo is gonna be 4r70w with 2800 stall (non lockup).
Here's where I mounted mine. No cooling issues at all.
ks
^ That's exactly where I have mine as well
Have a small one mounted for now until my bigger one comes in. Not putting the turbo on til next month. Just wanted to get the intercooler mounted and find a spot for the trans cooler.
I'm thinking of moving mine to the trunk. Right now it is out in front of my intercooler system's radiator. Doesn't seem to bother anything, mostly I'm worried about reducing nose weight.
Inside the trunk area or under the body by the trunk?
I was thinking of cutting a hole in the trunk for a fan and mounting the cooler below the fan and blowing down through it if I can find a safe space.
1 - 9 of 9 Posts
