1 - 9 of 9 Posts
Looking to swap out AR housings. Where can i get one for a 76mm turbonetics, q-trim?
Looking for a T4 tangential .96 or .81. with a 3" v-band. Any ideas guys? Thanks
Also if you would happen to know a ball park figure, that would be great
I am in the same boat here!
Any chance we can swap? What do you have now? What is your turbine wheel?
I have a new turbo that I need to swap the AR on. It has the one you need on it. 21594-68 .81 Tang / Und F1-68 mm
I need to swap to an on center housing with the 4 bolt pattern p/n 21607-68 .81 OC F1-68 mm.
It is new, still in the box.
This is what is on the box.
T_SE-BB-H76-68-TUNDO.81
P/N 11299-BB
S/N T-27543
DATE 101207
It is going on a 88' LX with a Boss/Eagle 302 with AFR 185's.
Code translates to T-series HP76 compressor, ceramic ball bearing, F1-68 turbine wheel with a tangential undivided .81 A/R housing. Basically a T76 with an F1-68 turbine wheel.
I have a T series and you a Q series, I belive that is for the turbine and the A/R may be interchangable. We need to get this clarified.
Pm sent
All the info I know and have is as follows
F1 .58 4-bolt tangential t4
I hate to send you there but Treadstone has them on their website.
P/N 21592-68 .58 Tang / Und F1-68 mm $220.99/ea
Ouch. Gonna see if I can puck one up used before I give them a call but I appreciate the info.
Yeap , thier good guys at least the ones ive talked to ..
How much did they charge you , if you can to say ?
Im thinking of getting a .84 for my t76 just in case im not happy with the .96
That way i can just change them on the dyno if need be .
1 - 9 of 9 Posts
