1 - 9 of 9 Posts
as the title states, I'm trying to get some ideas on the cleanest way to mount everything, Don't want it to be exposed to heat obviously.
X-2 Going to be hiding most of my lines, reg., and y. Like to see some pics if anyone has them.
the reg is mounted right next to he distributor. the return line comes out the bottom of the reg and under the intake manifold so you cant see it. working good so far
Changed alittle now due to going DIS.. No distributor..
Figured there's less heat up front..
The fuel lines connect to rear of custom fuel rails..
YES!! Right hand drive..
My regulator is on the right of the firewall, just under the junction in the brake line. 2 -6 lines go up to the rails, I use the stock feed line as my return to the tank.
-8 feed line from the tank goes along the "frame rail" up into the passenger wheel well to the regulator.
1 - 9 of 9 Posts
