Just like the title states, I can't seem to find somewhere that sells shorter end links. Also, what size are you guys using? I was told that these were a crucial piece to making the suspension handle to the best of its ability.
Thanks in advance.
Bob
Autozone? They sell Energy Suspension end links on the sales floor. I just brought out the measuring tape, measured the distance between the control arms and sway bar and bought the length of links I needed.
Wow, thank you for that. I was on MM and couldn't find them for the life of me. Are the Energy suspension ones decent?
....or you can cut the spacer tube to any length you want and then buy shorter bolts at the corner hardware store.
Yeah they're fine. Urethane bushings, grade 8 hardware, zinc plated. When you measure for the endlink length you want the sway bar "arms" to sit parallel with the ground.
