1 - 20 of 32 Posts
I need some advice on what to change about my suspension, I am trying to get better handling, but most importantly high speed stability and handling. I am building the car for bonneville salt flats. Here's what i have so far:
Front__-QA-1 Tubular K-Member, FRPP 3075-A Control Arms, X-2 Balljoints, Strange Adj. Struts, Steeda Bump Steer Kit, Steeda Ultra-lite springs, poly isolators, Billet swaybar mounts. Billet C/C plates
Rear___-Steeda Adj UCA, Alum. Lowers,4500 duro. bushings,Urethane Axle Bushings,Strange shocks.
I also have Steeda Full-length subframes
What can i do with the steering? New AGR Rack and pump, urethane bushing and MM Solid steering shaft. Still feels loose on center, seems touchy over 80-85mph almost squirrely, i just had an alignment done too. what gives??
What do i keep? What should i have instead. I plan on a 5-Link2 rear setup and i also have M-2300k brake kit.
Honestly....you need to trash your whole setup(maybe keep the X2's)and just go visit Maximum, Griggs, or Agent47's website.
Super Moderator
Have you actually measured the bumpsteer? What are your alignment settings? What's your toe setting when the front ride height is as high as it is when the car's going 80, not sitting still? You know this without having to measure it, if you know your bumpsteer curve.
I ordered a MM catalog today, Grigg's is just too expensive. I can keep the bumpsteer, x-2's, C/C plates, what's wrong with the rear control arms? my car hooks like crazy with street tires, i definitely want to go with MM's coil-over kit, K-member and a-arms, but i like the 5-link2 better than the torque arm for the rear.
i have no idea what everything is set too. Is there someone who makes a front splitter for the 87-93 frontend? This is also my street car, i just want to build something that will hit 200mph+ and have the handling capabilties to do so. Power won't be an issue, just working on the chassis now. It doesn't have to be top dollar stuff. But i know i need leaps and bound better than what it is now. and it really isn't that bad now, maybe just out of spec, it steers straight and doesn't pull or anything. We also have crowned roads in Florida and i am running 17x9's with 255/45's, so that may be some of it. stock sway bars and no strut tower brace or anything either.
Super Moderator
The bumpsteer curve is what it is...you make, borrow or buy the tools to plot the amount of toe change measured at different amounts of suspension compression and extension, and you make adjustments as necessary to get the curve where you want it to be. Most people try to achieve zero toe change, I purposely left just a hair's worth of toe out on compression. If you're even remotely serious about achieving 200 mph in a mustang, you have to know this kind of thing.
Throwing a bunch of aero and suspension parts at it now in an attempt to stabilize it without even knowing what any of the readings are would be like getting knee surgery and ankle braces just because you didn't realize your shoes were untied.
i am aware of that, but the parts i have now are not up to par......so i need to change them anyway. Is that correct or what i have is good enough, if i can have it setup more properly. the handling now probably isn't that dramatic, but it seems like it should be better even with what little i have done. I'm going to give MM a call tomorrow, and see if i can't take it back to steeda to be realigned and see if they can determine what my bumpsteer
Left front -1.0*cam. 3.3*cas. 0.20*toe Right fr. -1.3*cam.3.6*cas.0.13*toe
Left Rear-0.09*toe Right Rear -0.29* toe total toe -0.21* thrust angle 0.19* does that help?? That's my alignment sheet from steeda, that they did
Wait...you want to hit 200mph in your Fox body street car and you want to do it on the cheap? :lol::lol:
Good luck!
Good luck.:shakehead:lol: I'd suggest you ditch everything and stick with one brand. MM spent a lot of time and money making sure everything fits and works well together.
Discussion Starter #13
well i only need 500-550 rwhp to have a 200mph+ top speed in a 1.5-2mi stretch, standing mile i would need more like 900+, so with my 76mm turbo and dart block 331, i should be in the 650-700+ range at the tires, so power is not an issue. I agree with sticking to one company, i guess that steeda was not the right one for me to choose.
Anyone notice that there's been no discussion about safety devices (cage, fire system, etc...)
I predict that unless the course changes significantly, this will not end well.
My advice is to call maximum Motorsports, and Griggs Racing to see what they think will be needed for a 200mph speed run. take advantage of their experiance.
This will NOT be cheap, nor should it be.
Discussion Starter #16
I have my 09' salt flats rulebook, and a friend with a full service machine shop/ Dyno and a Ford Master Tech, with a fab shop to do all/any work i need. Labor is free just gotta pay for parts. I am also in the process of moving and purchasing/selling a house and buying a business. So this may take another year, but it'll happen and i'm sure i can do it for under $30k. I just want to hit 200 once it doesn't need to do it all day everyday.
well i only need 500-550 rwhp to have a 200mph+ top speed...
It takes 480hp just to hit 180mph. You need another 200hp for the last 20mph. So you need nearly 700hp to crack the 200mph mark in a Fox Mustang.
...i should be in the 650-700+ range at the tires, so power is not an issue.
Maybe...
p.s. Take lots of pictures, and more than one on-board camera, and finish you will before you go... then I will wish you... (ummmm...) good luck.
Discussion Starter #18
got the power part no prob, just need help with chassis/suspension and aerodynamics, they is actually some videos on here if u do a search, so i'm not the only crazy one.
Super Moderator
There's also a great thread or two here from people who have been there and done this if YOU search, might help round out the picture of what it takes to do ;)
You are building this car for the Salt flats?? And you live in Florida? You are stating that Griggs is too expensive but you are planning to tow your car all the way to Utah??
You have a complete mish mash of components, dont know what your alignment settings or weight settings are??
You need to stop what you are doing take a step back and then write everything down on paper..
The QA1 and strange are drag racing components.....
How fast are you planning on running??
1 - 20 of 32 Posts
