I have changed just about everything on this car except the fuel filter. Can anybody tell me exactly wher the thing is and if it is a big deal to change?Thanks. I located the Fuel Filter, it is between the gas tank and the rear bumper on the right rear side. I am having difficulty removing the little c-clips that hold the fuel lines to it. Do you just pry these up to a position and pull the line off or do you take them all the way off before you pull the line off the filter. Thanks
Look under the car in front of the rt rear wheel along the frame somewhere. You will need a fuel line tool to remove the filter.
if it is the same as the 90 I have, it is between the rear axle and the fuel tank mounted on the body. Just get some pliers, rags and new filter with new plastic clips. Pretty simple.
