1 - 20 of 20 Posts
Have not seen this topic addressed so I thought I'd throw it out here.
I am currently running '95 Cobra R rims with 275/40/17 tires (Pirelli's for the street, V710's for the track) all around on the car in my sig. There is room to move the rear wheels outward maybe 3/4" or so. I am curious as to what might happen to the handling with the wider rear track. The car is a daily driver but also is used for Autocross (12-16 events per year) and HPDE's (couple days per year, more to come this year - Thank You HPT). Future mods include front coilovers and, eventually, rear coilovers and new LCA's (The current ones have been on there a while).
Any thoughts?
Al H
push, plow, understeer......noticeably? Maybe not. How's the balance currently?
It will increase understeer. Most people who run sn95 a arms on the front are doing it to increase front track, and reduce understeer
Kart guys use spacers as a tuning tool.
Maybe a Kart site could give you more insights.
Well, I don't need any more understeer so adding spacers sounds like it would be a waste of time and money.
Thanks for the input.
Al H
I would like to run 1/2" or 3/4" spacers (do they make them this size?) for the rear of my car, and i was also wondering how SAFE they are to use on my daily driven Mustang?
H&R trak+ spacers
I don't know if you can space each rear wheel out .75", i used 25mm H&R hubcentric spacers on the rear of my car (6.25" backspace) and the tread of my 275s rubbed my rolled rear quarters a bit. It *felt* as if the car was a bit more level in corners, but this was probably placebo effect more than anything. I did not see a marked increase in understeer, however. your results may vary.
Are the SN95 arms shorter than the Fox arms or something?
Then why did Micha say that guys running SN95 arms will reduce understeer (due to the wider track), yet he says wheel spacers will increase understeer?
I don't think you should run any spacers in the rear without a PanHard Bar if you are tracking the car.
I have a 98 Cobra with 03 Cobra wheels. I installed 1/4" spacers before I installed the panhard bar and the tires were hitting the lip of the wheel well on hard cornering at Summit Point Raceway.
I now have a MM Panhard Bar and I run 1" spacers with no problems.
SN95 arms(front control arms) on a FOX will widen the front track, which will reduce front weight transfer which effectively reduces understeer.
He was refering to spacers in the rear, which would increase understeer.
If you want a safe spacer setup,go to Maximum Motorsports and get their 1/2"
hubcentric spacer with longer wheel studs. I currently autocross this setup on the front with R-compound tires with no problems.
http://www.maximummotorsports.com/spacers.asp
I run the H&R hubcentric 1 inch spacers on the rear of my Cobra with 275/40 Michelin Pilot Sports on R58 Cobra Rs... The rear wheels now sit perfectly flush with the fenders and I noticed no *dramatic* increase of understeer... Car is full MM tubular in front with a MM panhard bar and adjustable MM arms in rear...
Are longer wheel studs necessary? For the rear, using stock ranger axles, i'd like atleast 1/2" spacers. Do i need longer studs installed?
It all depends on how much thread is exposed after you put the wheels on.
If the lug nuts can grab 6 or more threads with the spacer + wheel on , you should be ok. Would you want a wheel falling off at speeds because the lug nut wasnt threaded in enough ?
Ofcourse not.. but the way it looks, you do not need longer studs with the hub centric spacers, only the "bolt on" or "regular" spacers. Is this true?
hubcentric spacers
yes, if you have the hubcentric spacers which have a set of studs pressed into them (ala the H&Rs which M/M sells), you do not need extended studs on your stock rear axles. you'll have to make sure that the recesses on the inside face of your wheels can accomodate any extra bit of stud that protrudes beyond the spacer, however.
Thanks for clearing that up for me.
I've got the R58 cobra rims on my car and am looking to get rid of the funny look of the rear wheels being tucked in. Will 1/4" MM non-hubcentric spacers work with my stock wheel studs? (kinda difficult to count threads with these wheels)
I'm gettin a panhard from them at the same time so i wont have rubbing issues to worry about anyways.
you're not gonna notice a very big difference appearance-wise, but you'll be able to thread your lug nuts in without resorting to aftermarket studs (if the r58s have the same specs as the konig villains). if you're getting the panhard, you can get the 25mm h&r hubcentric spacers that have integrated studs, and use them with 9" wide, 6.25" backspace wheels without rubbing problems. It still looks odd though, especially as you decrease fender gap in the rear.
yeah well i dont want to change the rear track enough to change the car's handling. I just wanna push those wheels a little closer to the lip of the quarter panel so that it doesn't look like the axle is too narrow for the car like all the rest of the SN-95s out there. I figured that 1/4" would make a small difference.
1 - 20 of 20 Posts
