1 - 20 of 25 Posts
Just like the topic says
NO drag radials
NO Et streets
JUST RADIAL STREET TIRES!!
Mine is a 1.98
:rolleyes:
Drag Radials are radial street tires. :)
umm mine is a 2.13 on FREE 225/60/15 cooper cobra's also a stock suspension to
My best 60ft on 245/50-16 Potenzas was a 2.01
That same day I averaged 2.04 on 7 passes and won the street tire class @ my local track :D
Brian
Edit-- They were 50 series not 60
1.92 on Potenza RE 730's
1.66 on the old style pep boys futuras 245/60-15's. at maple grove during the the motorsport nationals 2000. lots of rubber on the launch pad! recently, 1.75 with the newer style futuras 265/50-15 on a 10" rim. et's on the 2 passes were 12.18 @ 113 & 12.26 @ 112. 5.0roy
2.07 on a 2.73 gear on 245/50/16 Potenza RE 730's. The clutch was so unhappy I couldn't find second, and blew a perfectly good run. :( Backed it up kinda with a 2.11 later that night.
Just ordered some Yoko ES100's... I guess we'll see how those do soon enough.
my best time is a 2.05 launching at idle with 275/50/15 BFs. how do you slip the clutch and what rpm are you sub 1.99 60 footers launching at?
depending on the track conditions i'll leave anywhere between idle and 2800. as far as slipping the clutch....you have to look at it as if you were leaving a traffic light. you're trying to get moving as quickly as possible without blowing the tires off. basically, you'll ride the clutch slightly to bog the motor. once you get her rolling then you get on her. it takes practice(took me 3 yrs. and 7 clutches), but once you get it down......you can be a real sleeper! imagine the look on the guys face in the lane next to you when you drag his slick tired car through the 1/4 and beat him by 2-3 cars. especially if you 60' better than he does! i tell you, it's great! :evilgrin: :evilgrin: :joy: 5.0roy
In sig. 275/60 Hoosier radial. Run just as I do on the street (no pressure drop at track.
Last time at the track (April 12th), I cut a 1.901 (ET in sig), on a set of Hankook Ventus HRII's, sized 275/40/17, on a 10.5" wide wheel...
This was with my (since removed) AOD/3800 stall, launching from 1500 rpm's...
I haven't yet returned with a five speed...
best 60 foot
mine is a 4.98 60 foot (5.0GT to a 4 cyl. swap.) talk about a sleeper... that never awakes.
A friend of mine has gone a 1.83 with stock stires, suspension on his 03' Cobra, and it was street car night (no track prep of any kind) at Indianapolis Raceway Park no less...
1 - 20 of 25 Posts
