1 - 20 of 29 Posts
i used to run nothing but mobil one 5w-30 and a motorcraft filter. Those filters are the same exact thing as a purolater pure one filter. Its just got ford stamped on it. So ill be sticking with that, but after some research im finally switching to red line 30w race oil
Why 20w50?
What do you run ?
That's what im trying to figure out. I have a new dart 363 from fordstrokers and it has a pt88 turbo on it so I need to know a good start up oil then a oil from then on to use. I'm going to start it without the turbo first.
10W30 synthetic.
I figure with a turbo, you want something that is heat stable since it is running thru those superhot bearings
Erich
I have run 15w40 and 20w50 in my car for the last 2 years when applicable, but after doing some research I'm not sure thicker oil is better because thinner oil drains faster/better/easier. This is good for oil trying to get from the heads to the bearings and getting the oil out of ur turbo. I figured thinner oil was bad cause it breaks down easier with the added heat.
What are your bearing clearances? I run 10w30. Running 20w-50 is like pushing molasses through a straw, unless you have wide bearing clearances it isn't needed.
Jersey True Street Guy
20w 50 Valvoline conventional race oil per the advice of my engine builder.
Ran royal purple before that.
1 - 20 of 29 Posts
