1 - 14 of 14 Posts
hey guys what valve springs should i use>> 2004 gt turbo. im going for 600rwhp. 15-18 psi should get me there.
im going to be using stock cams. and stock heads
what seat pressure ???
is there a spring kit that out there that has everything a need??
(springs,seats,retainers,locks)
im also going to order valve guides through mmr. (only 100 bucks)
any help would be great.
custom 135lb stage 3 boost springs from mhs with the matching sized titanium retainers. they are oversized
ok great thank you. i dont know much about heads.
will these valves work with my stock cams? and since there over sized, is there any machine work need for them to fit???
im assuming i should buy new valve guides as well right??
just wondering thank you
well i believe the heads need to be clearanced to fit the larger springs. im not sure exactly how because i had mine done for me. Maybe Nick Mckinney will chime in and say what exactly needs to be done. I would go with the most seat pressure you can find. I believe the Comp high load springs have 125lbs of pressure. Bronze valve guides would be recommended for your combo
Get comp cams 120lb high load valve springs and be done!!!!!!
careful with using high pressure springs on the factory valves. you can break a valve and if that happens the head and piston are going to get damaged as well. i would recommend stainless valves also. i know thats not what you want to hear though.
lol no i deff dont want that to happen lol what valves do you recomend?
IM thinking about running the basically same set up but, I don't want a broken valve so I should go with 95# instead of the 125lb I picked out?
I run the high loads with .030 shims under them to bump the spring pressure up even higher. You have no worries about breaking a valve due to the springs.
1 - 14 of 14 Posts
