I'm thinking of running a Turbo on my 357w. I'm just wanting to go with 8-10 psi maybe a single 70mm with blow thru setup and carb hat. What would be best way to go since most kits are efi? Thanks in advance. -Rich
Sounds good. I wasn't sure if there was much extra I'd need. The on 3 kit it the one I was looking at. Is yours working good?
Haven't been able to put enough street time on it yet to judge much. I did have to open up the bolt holes on the manifolds quite a bit, but a few minutes with the grinder took care of it. Other than that I don't have any complaints.
I've done the 357w with on3 also... With a 1.69glide.. Runs good... (Good enuff it blew up my built C4 and that's why I went Glide)...
Decided to change cars also after tranny bit it... Lol
Building 98 now with cage, just about a back half car with stock suspension points still for classes... If u wana know anything just lmk...
As it sits now...
Not done yet but she's in the shop getting tub'ed, caged and "ready"... Needs wiring, fuel and final time with new set-up but I'll knock that out once it drops below 200* every day outside!!! Haha
Here are a few more pics of the build/swap
Here's mine as of now. I have a lot of room in engine bay. Gotta move alternator to drivers side. I don't have a heated garage to wrench in the winter so probably won't finish Turbo til spring. I'll post pics then.
[/URL][/IMG]
