I am going to change the T-Stat on my 03 GT, Procharged at 8Lbs. I believe the stock one is 192 and I have not removed it yet to see what one was in it. Should I run a cooler one? Will be doing this when I replace the rad, removing the stock one and putting something with more cooling capacity also.
I run a 170 t-stat on my supercharged 4V. Low speed fan comes on at 175 off at 165. High speed fan set to kick in at 195 and off at 175. I don't ever run hot, even sitting in traffic in the Texas heat.
leave the stock one in
you can have a tuner lower the fan settings a bit
the stat maintains the min temp, the fans are for the max temp
