I am in the mist of a diy turbo project and I am looking at the blow thru meters. they have a 3" and a 3.5" pro flow. I am looking at the 3.5" only to upsize the turbo in the future. I will be running around 8psi after the intercooler if all my calcs are correct. my pipe size is 2.5 but I would couple up and couple down at the meter. My question is with 3.5" meter will it read corrctly or should I stick with a smaller one. A friend of mine is giving me a good deal on the 3.5" but before I make a decision I figured I would ask around. the motor is a 306 HCI with a c4 tranny. 87 notchback. 70mm t body.
Can't give u any advice on that man but I am building the same setup as you, hci 306 garret 60mm with a comp c4. So I'm here to say I hope it goes well lol. And btw my car doesn't run yet but the maf that I use is a 3.5 pro m univer blow through meter. I think it will work well
Im running a 62mm and a 3in PMAS protube. I used 3in on the cold side form IC to the T/B to keep the same size pipe, I also made sure NOT to have any bends within a foot of the maf. before or after..
I suggest the PMAS protube !! Im sure its the only reason Im on the same set of headgaskets, and no tune. lmao
thanks not working on the car today it is 2 degrees outside.
If it makes you feel any better its 38*c here already at 10.15AM..
Near enough to 100*f..
