92 Coupe, all options,regular fan, no underdrives, battery in trunk, 30lbs of Dyna Mat.
302, .030 over
gt40 alum heads,not sure chambers,valves,"svo" engraved on ends,new in 05
gt40 upper and lower
bbk 65mm tb,spacer
bbk fender well cold air
comp cam, told 512 but not sure
bbk equal shorts
bbk off road
mac 2 1/2 pipe
full sub frame connectors
3.73
g-force t-5
msd 6al
19lb injectors
kc clutch
alum drive shaft
245/45/17 nitto drag radials
roller tip rockers
told car does not have a tune for the computer.
i ran it 2 times, it's been 18 years since on dragstrip,slow reaction time. I'm learning again. I've only driven car 300 miles since owned.
Discussion Starter #2
other info
5 way adjustable shocks on rear,coil overs on front with regular struts. all stocks rear arms and sway bar, 195,000 miles.
I got the head specs, theere GT40 Turbo Swirl #M6049Y303
Cam is Comp Cams, 512 lift, duration @ .006 tappet lift, 280, 280
duration @ .050 230,230
