1 - 11 of 11 Posts
Wix 51335. Super short, what I have to use
Motorcraft FL 910s is what most ppl use, short, but won't fit on my setup
Can you consider using an 90dg oil filter adapter(FMS) to run a regular filter?
I used an oil filter adapter off of an explorer and run a FL-820S. I don't have an on3 kit though..
I have a Fox On3 Kit and used the Motorcraft FL-910s. Fits perfectly.
I run the 90 degree adapter and stock Wix/Napa Gold filter. Fit is great and maintains better filtration and more oil!
FL-300 is the short Motorcraft version of the FL-1-A, a bit more filter area than the little FL-910-S. I'm not familiar with the clearance with that turbo kit though, so maybe the diameter of the filter is an issue as well as length?
cheers
Ed
1 - 11 of 11 Posts
