1 - 16 of 16 Posts
What RPM is everyone launching at be it on the track . Trying to figure out if I should buy an different rpm dial module as mine is 3000-5200 rpm's new motor should have a redline of 7200 rpm's . Thanks
soooooooooo many factors go into that one
i know guys leaving north of 9000 on NA motors
Stick? Auto? If auto, stall of converter? Gears? Tires? ect ect. As SRTthis798 said...So many factors go into this.
I leave at 2,500 rpm and the converter flashes to 6,200 rpm. That works for me and my combo. Probably not going to work for you Lol.
Usually either 500 below or above your stall on auto. You'll have to get it close and go up or down till the 60' falls off to truly find the sweet spot. My converter stalls at 5300. I launch my M2 C4 @ 5600rpm when running n/a & 3800rpm on spray.
N/A stock mach 4V, 4.56's, T56 w/2.97 first, 26" Hoosier slick, still have stock mach clutch. 6000-6100 as best I can with no 2-step. 16-18 psi depending on track prep. Consistent 1.50-1.53 sixty foots.
  • Like
Reactions: ez2memorize
Typically between 5000 and 5500. The technique of getting there seems to be important for me as well (launching while holding the rpms versus launching while reving)
If you ask 10,000 people with different set ups you will get 10,000 answers.
For example, my car would never move off the line if I left anywhere near at the stall. It would either shake apart or smoke the tires.
My converter stall is 6500, and I never have been able to leave at more than 5400 on any track with any tire. Sometime I have to leave at 3500 depending on track and tires.
When it was a stick, I had to leave at 6000 and let the clutch slip on some tires and tracks, and on other tires or tracks at 3500.
Good advice ready, but for giggles:
331, 3360lbs, T5, 4.10's, ET Streets, 6,000rpms and 1.5X 60fts.
Joe
agreed on the 1000 people giving a 1000 answers...
but, what the heck...
little 306 with stock heads and solid cam, 2.95 1st gear, 4.56 rear gear, 26" tire... street car 3270 race weight.
I hold 5500-6500 (track conditions dependent) and before I dump the clutch I shove it to the floor... so, some where north of that. :shrug:
To be honest, I was still figuring things out...
I stall at 5600 and my car likes a 4800 pill
4.2l v6, s366 turbo, 4r70w, edge converter, 373 gears, 28"et pro, n2mb 2 step set at 3200 rpm, 1.29 60' 6.39 108 mph is the personal best.
weight 3420 26in slicks T5 stock 93 cobra motor 355 gears 1.56 60ft 11.3 at 118 mph leaving at 5,000rpms no 2 step
1 - 16 of 16 Posts
