1 - 20 of 22 Posts
What radiator and electric fan setup are you running in your street driven turbo cars? Im using a motorsport rad and black magic fan. It worked very well before the turbo was put on. Now the car runs too hot. Would like to know what really works. Thanks
Jersey True Street Guy
I have a 2 inch 2 core aluminum and a summit dual fan setup.
Not really enough on my car, runs hotter then I would like
Champion radiator makes a 4x.75 core that is reasonably prices.
Also be careful of putting things like transcoolers in front if radiator.
My brother had a black magic on his NA 351w car and it couldn't keep it cool either.
All aluminum 3 core from radiatorclassic.com $130
Lincoln Mark 8 fan scrap yard $40
Summit Racing variable speed control $99
Setup is awesome, the fan control has a startup delay and a 30 second run time for cool down.
Northern 2 core/taurus fan set up. Had to trim it a bit to fit, other then that, its been perfect.
Mark VIII fans work great and are cheap.
That plus a generic aluminum rad from summit work really well for me.
Erich
Not sure that it matters on the mark.
Erich
On the mark VIII fans, I believe the first few years were 5000 or 5500 CFM and were louder. Then they slowed them down 500rpm. I'll try to find the info and Siemens motor numbers. Same thing on the taurus fans.
Anybody try the 2000 Contour dual fan?
Thats what i run, except mines from a 99 cougar,v6 same thing.
And i run the 35 dollar adj controller from oreillys
1 - 20 of 22 Posts
