1 - 12 of 12 Posts
Okay I am going to get a set of LCA's this year because my traction in first gear is an absolute joke. Whether on the street(97%) or on the track(3%) the car CANNOT hook.
I will lower the car soon, and I know that this can kill traction due to suspension travel and the consequent loss of energy through the stiff springs (I think) If I lose it through the springs it must spin the wheel?
Anyway, here are the concerns and questions:
1. Go with adjustable or non?
2. If the car is lowered and I put LCA's in will it affect ride height?
3. The higher the setting of the LCA I would assume the better the traction?? Vice versa.
4. I want them for straight line traction BUT I do a lot of "twisty road driving and I don't want to sacrifice any type of cornering due to them.
5. Finally, with my setup will i get some of the traction I am looking for?
Any input/answers would be greatly appreciated and will help a lot of us in understanding LCA's better. Thanks
Talk to MM and tell them what you are after.
They will set you up with a fine bang for the buck suspension.
Go with the Pro3i Street/Race LCA's. They are an almost identical copy of the MM LCA's, but they are $70 cheaper. I would stick with the standard LCA's personally. I have the MM LCA's on my 88 5.0 and the Pro3i's on my Cobra. Both are the standard versions with spherical bearings on the axle end of the arm.
www.partshopper.com I believe is the link. If not, try www.stangnet.com and click on the "Partshopper" link.
Ditto! I've got them. Unless you want adjustable then prob UPR.
Whats the great advantage about adjustable and why would I want to do it? I am not a die hard track race just street. Ive read some of these guys mix matching some of there UCAs and LCAs. Does that matter?
Thanks for your help.
For the street and twisty roads you will want to spend the extra $20 and get the Street/Race version with the Spherical bearings. The arms with the Poly bushings in both ends will hook decent in a straight line, but will create more rear-end bind than the stock arms on the street while cornering.
I think I got my arms for $184 delivered. If you buy from Hotpart.com it comes to $173 delivered with the free shipping. I say buy them from Hotpart and save an extra $11. Good luck on your decision.
Thanks for the tip. I just called them and changed my order:cool:
I am in the same boat. I am about to drop my 97 cobra but I am gonna need traction bigtime since my KB will be installed in the next few weeks.
I am curious to see what will happen if I use Eibach Pro's and these Pro3i Street/Race LCA's.
I don't want it to low but I deff. want to get rid of the 4x4 look.
So the poly bushings on both ends actually make your car loose the rear more in street driving? Thats not what I want. I want something to help me hook at the track but still help(not hurt)on the street around curves. Anything out there like this?
LCA'S
I did both, lowered the car and installed the PRO3i's LCA's(street/race). Seems like the LCA's raised my rear a bit after the install(car seemed lower with just the springs). Also, my car still spins the tires. In my opinion the LCA's alone won't cut it. I figure i need a set of drag radials.
As far as the cornering goes, i wish i could give some input on that, but we don't have many twisting roads down in Miami.
1 - 12 of 12 Posts
