1 - 8 of 8 Posts
88 GT. 1969 357w,11.1cr,crane hydraulic nitrous 533lift
cam, Windsor heads w/ port work, bigger valves, studs and gulid plates, Vic Jr intake,850 carb, Hughes C4 transmission with 3200 stall,manual valve body, 3.73 gears
Discussion Starter #2
I just got the car Saturday that's all the information I have on
The car at full weight, been gutted? cage? what tire? I mean im going to guess 7.20-7.40 but that's just with info given
depending on traction, mid 7's
thanks 4 the info guys..would it be better to stick with 3.73 or go to 4.10 ???
I would probably leave the 373's and see how it does first. it's not a bad all around gear for some strip and cruising also.
1 - 8 of 8 Posts
