1 - 20 of 29 Posts
i got a g-force straight cut tranny with 373 rear gears. currently im supercharged and is wondering what everybody is running on their turbo stick setup. i'm building a dart 408 with afr 225 and putting a bw s480 turbo in. i know i won't be as consistent or fast if i had a auto, but i like challenges and banging gears.
Depends how high you you want to turn that monster.Should be a fun ride!!
I was running 3.73s with my stock block turbo on 28s. Maybe try them out first?
prob shift it 7000+. i have another question. i wanna run a 4 barrel efi carb w/ hat. i have a super vic efi intake. should i go with the 4150 or 4500 tb w/ 4150 adapter. do i need to go with the bigger tb even though it will be turbo forcing it or will the 4150 work. i also got a buddy with an auto setup who wants to trade me for his.
A lot less power, but we've tried 3.08 3.55 and 3.73 in our turbo stick cars.
One car is a 351 Gt40 top end 14psi with a tko 600, it had 3.08s in it, switched to a 3.55 and the car picked up tremendously.
We roll raced a turbo bmw before and after the gear swap, had him by maybe 1 car with the 3.08 gears.... 3.55 we yanked him by 3+.
No changes other than that to either car.
My car is a stockish 302 with 3.73s and 8psi from a 70mm, it spools like a freak but i have trouble keeping it planted with 275 street tires. My buddy with the windsor car is contemplating trying 3.73s as well.
i guess i'll just have to just try it out. but i'm still on the fence either 4150 tb or the elbow. plus i'm worried about clearance going to a taller motor with the 4 barrel
All depends on your setup. The longer gears are supposed to help with the lower gears and spooling.
It makes sense that it would be slower from a roll if you have some high rpm setup
I started with 3.73's in my turbo car and decided to try 3.27's and have not looked back. Really like the gear, with my T5-Z I can cruise at 65mph at under 2000rpm and still get more than enough spool in 1st and 2nd gear to blow the tires off.:evilgrin:
Combo is a stock block 302, trick flow street top end, and a hellion kit with a turbonetics T66 turbo, running AEM EMS for tuning.
I think it depends on your power band...I went to 3.27s from 3.73s and honestly, with my powerband they arent anything special and the cars probably slower than when I had the 3.73s.
My powerband sucks currently and is more like a centri blower power curve than a turbo curve so thats probably my real issue.
I dont have that broad torque curve to pull me through the rpm, hopefully the stock cams change that though.
Your auto, he's talking stick car, so you'd need a bit more gear
My Gforce T5 grenaded 3rd gear with a fairly mild twin-turbo 331. I don't think yours will hold up long with the kind of power you'll be making.
hows that go...a fairly mild twin turbo 331...
Sent from my rooted, rommed Galaxy Nexus....
Discussion Starter #15
what kind of g force do u have straight cut gears or helical.. i know they all are rated at 600 but maybe the straights cut might be a lil stronger. i'm just hoping for the best and ur prob right thomaswpt . lol
that car's going to make sick power so i'd say 331s/327s or possibly 308s. i swapped from 373s to 331s and the only regret is that i should have done it sooner. my 550 tune with 331s now feels like my 650 tune did with 373s.
also, if i was you i'd sell that Gforce T5 before anything brakes cause it will NOT survive the torque of this turbo setup. i was in similar boat and sold by astro super T5, and got a viper spec T56.
pk
Discussion Starter #17
what tranny would u recommend as a manual also a auto. my buddy has a c4 who wants to trade me, but am skepital if it can handle the power. this car is prob gonna be a 50/50 street strip car. i do like to cruise it and bang gears and don't wanna trade him b/c i think my setup is worth more but that's just me.idk if it is lol. str8 cut dog ringed w/ g force case and everything else quicktime bell housing and hydraulic clutch.
viper or mangnum spec T56 as the only way to go.
not an auto guy so can't comment on it.
pk
I've watched stock t-5s handle 500hp.... don't bang the gears. mine took a blower setup making 380ish for a year, no problems... and now is holding my turbo motor making probably 400+.
Just be mindful of that t-5 when you're playing.
Power shifting, clutch dumps, etc. The power isn't what kills them, it's the shock... Just my .02
Have 4:10s with a 67mm on a 331. Blows the tires off 1st - 4th. Only had them because I originally planned s/c instead of turbo. Going to a 3.55 soon
1 - 20 of 29 Posts
