And is it worth it. The car is a weekend driver so I don't mind the maintenance of adjusting lash.
So what do I need?
  • *cam
    *solid lifters
    *pushrods?
That's about it. You'll probably also want a good set of roller rockers if you don't already have them.
I assume that this is going into a car that already has heads / intake / exhaust and can take advantage of the cam?
If you go with a tight-lash solid roller cam, you won't need to adjust the lash as often. I think I have to do it maybe 3 times a year... and the car is auto-xd / open-tracked just about every weekend.
Later,
John.
