so i have this 347ci turbo mustang with a front mount intercooler im running around 30psi through it im sure its a restriction at this point thinking of ditching it and running alcohol injection to cool the charge down rather then the intercooler.
my question would be if i keep my meter as a blow through it will see the intake temps out of the turbo with no cooling or minimal cooling if i spray before the turbo, what air charge temp will the maf sensor melt/quit working/become inaccurate has anyone had any expierence with this??
theres really no way to convert to a draw through since the turbo is out in front of the car
-thanks Ben
Check out yellow bullet; there is some serious racers there. 30 psi is an insane amount of boost; I haven't seen guys runnnig that much over here.
So let me get this right u run 30psi AND u still have a maf? Damn they do make standalones like Megasquirt or AEM. The corral is "level 1 tech support". Go to the turbo forums.
thanks guys will do, im kinda one of those dont fix it unless its broken. maf has worked fine for me up till this little bump
