1 - 14 of 14 Posts
Lets see all the Weldons!!! I just got a DB2025 and looking for alternative mounting in the rear bumper and or trunk area!!!
AWESOME AWESOME first pic post!!!!!!!! Lets Keep Em Coming!!!
most Weldon pumps are self priming so it is not necessary to have them below the feed line... they can also be mounted horizontally or above the fuel cell.
Yeah I wonder if anyone mounted one in the trunk with a bottom tank and it worked? Seems like you would like always have to have a full to the top tank if mounted really high.
Also lets see some sn95s with Weldons as the foxs have different metal work goin on under there...
Here is how I mounted mine on the 95. L bracket that is attached to the bumper support. The inlet filter is attached right to the pump, and the other filter is mounted on the front of the gas tank cover.
Discussion Starter #13
GREAT PICS guys!!! I have mine installed now and using it daily to drive to work! I also just put an Aeromotive controller on it yesterday to slow it down as it moves a-l-o-t of fuel! Any rubber mounting pads and or noise isolation tricks you guys have sucessfully used to quell the vibrations?
Also.....can I send somebody pics to host for my install? It looks quite a bit different from the examples above!!
hard to see pic but its the best i could find, i have since gotten rid of my weldon because it was a PITA on the street even with the dial-a-flow controller.
to answer questions....
YES, you can mount it in any position including above the pickup. BUT in my case it was a headache to get to prime with a full tank, let alone anything less. you can see that the pump was mounted at about the half way point of my fuel safe cell (22 gal). it would not prime to full pressure during the 2 second prime setting when turning the key to the "ON" position. So I have to prime the pump at least 3 times before every start. another PITA with this pump is that is doesnt have any drainback prevention device (check valve) so as soon as you shut the car off all the fuel drains back to the tank and goes to zero pressure. again, causing the priming to be a pain.
I had both pre and post filter on it, running a -12 feed from the stock location pickup to the pump and -8 to the rails.
I mounted it by some 1/8" steel I bent in an "L" shape and moutned it to the rear bumper support and put rubber isolators between the pump and the bracket to help hinder sound. even with the controller it would be loud enough to hear over the 3" dumped exhaust.
I could see that some love this pump because its capable of flowing a ton but for me, driving on the street, I had to get rid of it. BTW, on the street with the controller all the way down the fuel would still heat way up.
Ive since switched to dual pierburg pumps and will never look back
1 - 14 of 14 Posts
