1 - 12 of 12 Posts
Does anyone make a V-band flange that I can weld directly onto the a T3 exhaust housing?
I am looking for a ring/flange that I can weld onto the exh. housing that goes from the 2.5" opening to a 3" V-band.
thnx
ks
They're not 2.5" 4 bolt outlets?
Nope.
I've also contacted the builder of these turbos so see if he has a 4-bolt version that will work but I haven't heard from him yet but even if he does I "think" I may still want to weld on a flange for space limitations.
ks
CXRacing has the adapter flange for 4 bolt to 3 v band. A couple of them came with their twin kit.
Formerly known as 20thAniv
Have you checked with Racepartsolutions.com? If they don't have it, I'm sure they can steer you in the right direction.
I couldn't find what I wanted there. I've seen the 5-bolt flanges with the ring already welded which may work but I don't want to deal with the flange.
Like most everything else I'll probably have to make it myself but I was hoping to just buy one. No big deal.. I'm in the process of designing my own front sway bar to work with all the turbo piping.. $$$ :(
ks
Are you looking to mount a 4-bolt turbo onto a v-band hotside? I found out the hard way my 4-bolt turbo was an older style that used an on-center exhaust housing. Newer hotsides assume you are going to mount a tangential style exhaust housing. After paying to have my 4-bolt flange cut off and a v-band flange welded on I discovered the turbo would not fit properly onto the tangential hotside. $100 lesson. But I remedied the problem with a newer and sweeter turbo :)
No. I have two new turbos that use a 5-bolt downpipe flange and I'm going to convert them to use a v-band flange. Due to possible space limitations I'm just going to weld on the v-band flange onto the exhaust housing instead of buying those "5-bolt to v-band" adapters.
ks
Discussion Starter #12
1 - 12 of 12 Posts
