I bought a Kestrel 4250 portable racing station and need to figure out how to best use it. I believe the most important measurements will be:
Density Altitude
Temperature
Relative Humidity
Moisture (grains)
Pressure
Wind speed
Of course DA uses temperature, pressure, and humidity and compares the air to standard temp, pressure, and humidity but it seems at the same DA that I am more affected by humidity than temperature. I hear people talking about grains of moisture independent of DA. I understand that relative humidity is dependent upon temperature so grains of moisture is probably an absolute measure of the water in the air.
My questions:
1. Should I be looking at any measurements other than what I listed?
2. How do I consider relative humidity and/or moisture (grains) in figuring what I will run to be more accurate than just using DA?
3. Is there any good software or reference material to help figuring what I will run? I know some meters have this functionality built in but they are more expensive too.
In my opinion the greatest influence is DA and Barometer
On that note if yours doesn't do Barometer...send it back and get one that does.
I've noticed that even when the weather's "good" - i.e. cool with decent pressure - I can still run slow if the GoW are high; easily enough to offset the temperature benefits.
GoW is grains of water? I think you are saying what I believe also: humidity affects me more than heat. To me this means not all DA's are equal ... lower temp and higher humidity is worse than higher temp and lower humidity. Other than logging a bunch of runs (which I will do) is there a good rule of thumb to understand the impact of humidity or grains? I'm not actually sure what grains of water is telling me compared to humidity. Possibly just an absolute measure vs. a relative measure I guess.
