1 - 9 of 9 Posts
My 96 GT temp gauge has been out for a while. I have been told it is my temp sender (or sending unit?). My brother told me its an easy install, just screws on, and I might lose a little coolant. Is this an easy install? I'm no mechanic. The dealer said its around $100 to fix. Isn't this a $20 part? I would like to try to fix it myself if possible. Thanks!
US Air Force Active Duty
My wife could do it. Including opening the hood, finding tools, and changing the part it takes about 10 minutes. :)
If you open up your hood and look on the very front of the intake, there's a temp sensor on each side on the top of the intake. One controls the temp gauge, and the other sends a temp to the computer. I **think** the 'gauge' sender is on the driver's side, but I'm not positive. The Ford dealer should know.
Here's a link to a pic of the temp sender's location:
The red circles outline the temp senders. Notice the driver's side in this pic has a plug instead of a sender, though.
Hope this helps.
-Pat
Just thought of something else.
Walk straight into your dealer's service center and kick the manager square in the nuts. $100 is a ripoff--like I said, it takes 10 minutes to change and I'm pretty sure it's not a $70 part.
-Pat
Thanks alot for your help! Will I only need to replace the driver side one, or both? The bastard probably wanted to charge me $100-they had to replace my cracked intake under warranty and I don't think they were too happy about it.
If you don't have a 'check engine light', you should only have to change one sender--the 'gauge sender'.
-Pat
-Pat
Yeppers... one of them is the "temperature" and the other is the feed for the "EEC/Computer".
This is an easy install and I'm sure you can accomplish it!!!!!!!
related subject
I just got a 180* fan turn on kit. Since both water temp fittings are used on a '98 GT, would a t-fitting in one work to get two sensors into the same hole and still be in contact with the coolant, or will I really have to tap a new hole in the intake? The kit (from IST) has its own temp sensor for fan use, but keeps the stock one for the EEC for other engine functions. I also don't want to lose my temp gauge! Any advice would be appreciated.
Yeah, I've read about using a manual switch for the fan, but I don't want to have to mess with it. I'd prefer it to come on automatically.
1 - 9 of 9 Posts
