1 - 11 of 11 Posts
Looking to install my wastegate on my 4.6.
Its impossible to install it where the pipe merge before the turbo.
Since My turbo isnt a twin scroll,
Can i install the wastegate before the merge pipe on one pipe with good result?
Discussion Starter #2
do i didnt have enough space to fit the wastegate like this one
the cheapest solution is to install the wastegate like that
is there any problem to run it like that?
and is this location with the wastegate turned down at the merge pipe is effective?
How much boost are you looking to run? If it were mine i'd prefer to install it like the last picture you posted, however, as long as your merge pipe isnt a divided t4 flange, the second to last picture would work also. If your looking to run a ton of boost with the later you could run into boost control issues if your wastegate isnt large enough.
I've done it like the second picture but direct in the elbow with a transition pipe.
Should be ok i hope
1 - 11 of 11 Posts
