I want to replace the bezel around my heater controls and radio from my 99 single din radio so that I can install double din 2000+ style newer radio.
Let me know if you have one available, don't want to spend alot since this is a "test" fit.
Thanks, send me a PM
That would be an 01-04 model. And it does fit, but you have to cut off the 2 screw hole areas behind the radio. The 01-04 model doesn't use that (the area between the din's).
Thanks for the clarification on the 01-04, I have had my bezel off and could see I would lose those screw mounts. Thanks again!
