Was working on tapping my pan to install the 3/8 NPT oil drain fitting. For what it's worth, the fitting is an aluminum one rather than brass.
I punched the hole using a plumb bob which seemed to work out great. I marked on the plumb bob how deep to tap in and once that was done I worked on threading the hole. The tap barely wanted to go in and it took me a good hour or so to tap the hole. I finally got it through and it created some threads.
Now for my issue - I cleaned it all up and went to install the 3/8 fitting. It seemed to thread in fine. Was a tad snug but not bad. I got about half way in and then I noticed it loosened up. I pulled the fitting out and the threads on the fitting were pulling off (threads are still there, just half of what they were). I ran the tap through again and it threads in fine and I can still visibly see threads but the fitting is junk now.
Any help would be appreciated before this somehow turns in a giant mess. I ordered a new fitting, along with a brass one to test the threads out with first. Any idea why it might be pulling the threads off the fitting?
