1 - 8 of 8 Posts
So I have a mustang fox with a v3 si.
I have the vortech mondo mounted on a vortech discharge tube.
My question is how have you guys connected your bpv to the air intake. I'm using an Anderson air intake.
I know Anderson sells a bypass mondo kit for this but it is mucho money.
Anyone have opinions or pics of their setup.
I will get pics later today of exactly what my problem is.
what type of inlet tube are you running? if its steel,you would need to cut about a 1"-1.5" hole in it,and weld a nipple,or short piece of tubing to it
take the mondo bypass and mount it with the discharge from the bypass pointing towards the inlet tube
then attach the two with a hose,i think what Anderson uses, is section's of a radiator hose
Yes that was my plan. Now that I have everything locked up my issue is the tube would have to be in the rubber elbow that connects the Anderson to the charger.
My three ideas are.
1. Find a 4" elbow with some type of plastic bung on it
2. Cut a round hole in the rubber elbow install pipe and epoxy (ugly)
3. Possibly weld tube on the very end of the tube and cut the elbow around it. The only reason I don't like this is because it would have to angle towards the maf.
Here are some pics.
My three ideas are.
gotcha, i see what you are talking about.. what Billy has seems to be a good setup if it will attach to the powerpipe after the elbow
1 - 8 of 8 Posts
