I would recommend the 8" renegade lower for maximum belt wrap on the blower pulley. You'll need a 93 cobra wp pulley as well. ASP make reproductions.
so you switch to a 8" lower, then smaller upper? Anyone run a 10 rib, or is 8 rib good enough on an SI trim?
going that route,depending on what size head unit pulley you go with,would be stepping up the boost quite a bit..
do you have a ballpark figure you are looking for on boost levels?
